QUOTE (pauliebanger @ 27 Oct 2013, 23:21)
<{POST_SNAPBACK}>The Android app is called 'Engine Driver' and is a free app.
Ah, but, it helps if one is describing the same things:
TouchCab - an App for Apple devices for direct (no extra computers needed) communication with supported command stations. Those being the ECoS and the Lenz system (through the Lenz computer interface box). If owning an Apple device, and already owning an ECoS this is probably the simplest solution. There is no Android equivalent App.
EngineDriver - an App for Android devices which can communicate with the WiThrottle Server which is present within the JMRI software application. JMRI runs on Windows, Macintosh or Linux computers, and can then communicate with a DCC command station. For the ECoS there are some limitations of what is possible from JMRI over the Ethernet interface into the ECoS because ESU are terribly slow at releasing documentation of their interface protocols (or conceivably haven't written the capabilities yet). The JMRI website lists the capabilities supported, and driving trains is supported.
http://www.jmri.org/help/en/html/hardware/ecos/index.shtml
So, to use EngineDriver, one needs a small computer in the middle of everything. This can be a fairly basic or cheap device, even the £25 Raspberry Pi can do the job (though is a bit of a hacker's special, something with a little more power and more conventional is simpler).
WiThrottle - an App for Apple devices, which can communicate with the WiThrottle Server. See EngineDriver paragraph above.
- Nigel
