Peco point motors are quite crudely engineered compared to what's available from European manufactures, therefore they are power hungry beasts requiring something like 4 amps to operate - compare that to a point motor from Fleischmann or Roco that takes around half an amp................
Your point motor probably is on the limit for your supply & takes just that bit more on the AC side, hence tripping the unit. 2 - choices - feed the point through a CDU (probably the cheapist & easier option) or find another supply just for the point.
Hope this helps.
Hope this helps.
