Hi all,
I fitted a 4 outlet loudspeaker lever terminal block to the front frame of the boards last night to supply 12DV & DCC power for a small pull out shelf with a length of track for testing locos on DC before conversion and to house my ESU decoder tester.
Supply for the tester come from the main layout bus wires, after connecting up i tested two decoders using the NCE Procab control though no locos were on the layout.
Is it possible to read decoders and reset for example to 03 using it this way and not to conflict with any locos on the layout or does it need connecting to the programme wire feeds to the base unit or is it in the right place now ?
