QUOTE (neil_s_wood @ 14 Jan 2008, 17:06)
<{POST_SNAPBACK}>For those who do have a go with the SwitchPilot, I received this advice on how to program them. This may be of use to others so I will replicate it below.
Dear Neil,
I try to give you a short instruction how to get the CVs read and write:
1. if you are not able to adress the SWP via the decribed procedure in the instruction (program switch on the board, yellow LED etc.), the SWP is failed. This failure has been reported several times in the forum and is based on quality problems during the fabrication of the first batches.
2. in order to read and write the CVs first you have to connect the SWP with the programming track. Parallel you have to use the same connection for the power supply.
3. please don´t connect any output channel with a point machine or something else. Only connect the output channel 1 (OUT A and C) with a resistor of 180 Ohm. You also can use a lamp. This is important!
4. Open the menue for decoder programming in the ECoS. Fill in the correct DCC adress! This means, with regards to the created point on the point panel, you have to use the DCC adress 1 for the point no. 1 to 4, the DCC adress 2 for the point no. 5 to 8 etc. Select the programming track and DCC.
5. Now you can start reading the CVs and writing the CVs.
6. For reading and writing the CVs from the main track you have to write the value 6 to CV 28 and the value 136 to CV 29. Afterwards you can check reading the CVs via main track while selecting the main track, DCC mode and point load.
7. When everything is ok, you can install the Switch Pilot and connect the points.
It is very important to note the part about the power supply and resistor across output 1 during programming!
Hi Neil,
Thanks for the help, I just joined this forum, b/c its about the only place where english speaking people seem to be using ECOS + Switchpilot.
I am still confused by the addressing of switches and accessories. The SWP has its own address (Just like any loco has). While the points have different addresses. I have been scouring the ECOS forum, but sadly my german is too basic.
If you have any pointers I would be greatful.
I use tortoise switch machines, and I must say so far all I got from the SWP is a LED plugged in the output channel 1 that I get to blink!
Fred
