I too use Superglue, but not the gel as this is more globular and if you're not that experienced at applying it, you can easily squeeze out slightly too much, and you might only see it when you locate the nameplate and get more out the edges as you press it lightly into place, making sure it is perfectly straight. Only the tiniest spot is necessary to stick them on, and if you are re-lining too then I'd finish off with a pass of Satin finish clear lacquer to seal it.
But that's only what I do..."a little dab 'l do ya!"
jules
