QUOTE (Walter @ 29 May 2008, 16:47) <{POST_SNAPBACK}>Hi,
I have a Farish 66 and a spare six-wire, two-function Uhlenbrock 73400 dcc decoder from another project. Six wires, as there is no blue lead for the common function return. In a lot of N gauge models this runs via the chassis.
The Farish 66 has 7 solder tabs.
Would the two work together?? Could I just leave tab 7 (common function return) empty in the absence of a blue wire on the decoder, or is that not going to work with the lights?
Many thanks
Hi Walter,
I have just fitted a TCS M1 decoder to a Graham Farish freightliner/shanks loco following this link
http://smallphry.com/eecore/index.php/site...dcc_conversion/
click on the images for a better view of them, i did line the inside area where the motor tabs are with kapton tape and underneath the solder points on the chassis as a precaution.
As to the blue wire as far as i know it is the common positive for lighting, and its omission will leave the lights useless.
upnick.
Many thanks
Hi Walter,
upnick.
