The roof was covered in Scalescenes' roofing slates. Next, the awnings were added. To replicate the heavy wooden brackets which hold up the main awning, I fabricated them from card strips and soaked in superglue to harden them...
They were painted a suitable cream colour and glued in place beneath the awning...
The wooden platform on the rail side was fabricated from a strip of 1mm greyboard covered in Scalescenes' clapboard to match the floor of the shed. The supporting wooden posts were cut from mountboard and coated with superglue to harden them before painting. They were glued in place and aligned by eye.
Problem requiring a solution: how to represent the open wooden steps at each end of the wooden platform? I required some thin (but not too thin) card. A discarded tissue box was ideal. Firstly, I took some measurements from the model to work out the length and width and to establish the correct angle of the stairs. The measurements were transferred to the card and a simple diagram was drawn. A strip of the card was cut off and from this two sides and five steps were cut. The sides were offered up to the diagram and the angle of the steps marked thereon. The procedure was repeated for the second set of steps.
One end of each step was glued to one side on each pencil line and levelled-up by eye. When dry, the other side was glued in place. Once the second side was firmly attached the whole staircase was given a light covering of superglue, using a cocktail stick. This was to harden the card and to firm-up all joints.
Both staircases were given a couple of coats of paint and glued in position on the model. Job done!
