QUOTE (Ian Everitt @ 25 Sep 2012, 19:18)
<{POST_SNAPBACK}>Have to say that my favourite parts of this layout are the signal box and the goods shed
I just hope that when I make my signal box it looks as good
Hi Ian. Thanks for the comments...
You flatter me your exelency!
The Station Building
Basically this is the Ratio "Castle Cary" kit, with a replacement roof, proper canopy supports, and a few other modifications.
Some of the most noticeable changes are the Slate Roof (Wills sheets) and around the Road Side the "Extension" was not fitted, and a small canopy made using the flat roof from the "Extension".
You may be able to spot the scribed filler where the corner stones for the extension were meant to go.
The Slate hung gables are also Wills slate sheets.
The building is painted in GWR colours, and to resemble sandstone. (I am assuming the staion was re-painted in the late 1940s, just before Nationalisation.)
The Main Canopy supports were made from plastic tube and strip.
As supplied, there is no visible means of support for the main canopy at the Booking Office end. You will notice how many on peoples layouts have a sagging canopy!
The kit is "based" on Castle Cary, but the Castle Cary Canopy has supports built into the building, a quite common arrangement.
http://en.wikipedia.org/wiki/File:Castle_C...form_1_-_01.jpg
The Ratio Canopy has been designed so that it can be sold as a stand alone item, with different supports.
The screen around the Gents Toilet Door is Plastic Card scribed as planks, and framed with Plastic Square Sections, replacing the Concrete Fence supplied in the kit. (This has been used by the water tower.)
The Booking Hall Doors are modified into double doors (Modelled open). As supplied there is a single door with a window alongside.
The station benches are from CooperCraft kits. You get spare "ends" in 2 styles, so with some plastic strips, you can make more benches.
The poster boards are computer printed.
