QUOTE (TonyUSA @ 20 Sep 2008, 21:07)
<{POST_SNAPBACK}>Hello Richard,
I have to admit I am new to using the Model Rail Forum and I am having a problem trying to attach some pictures I took for you of the decoder installation. The insert an image button comes up with a script promt and asks for a URL, the pictures are just in a folder on my commputer. How do I get them to attach to the message? I have tried copying over, but that does not work. I cannot find any help info on the site about attaching pictures.
I did examine the installation and I still cannot see anything wrong. Why does the loco run perfectly on the factory default 03 address both forward and reverse? i would have thought that if there were any shorts or the installation was incorrect, it would not have run at all.
Thanks for any guidance,
TonyUSA
***Hi
To add images you first have to post them online in a photobucket or similar image holding website.... there is a thread explaining this in detail.
re the decoder your question is a fair one. it SHOULD be Ok if it runs on 3.
can you put it on aprogramming track wired to the programming track outputs of the DCS50 and get the controller to read the decoder in paged mode (Pg on the digitrax display)?
If install and decoder are both OK, then this should be no problem
