Yes, it is equally OK for AC, DC or DCC use. It will give constant lighting with no flickering on all power types. It will make sure the lights stay on for AC or DC layouts, even when the train stops as there is a LOT of power storage - supercapacitors with more than 200,000 microfarads.
The flickerfree is totally regulated on input power use too so there is no significant power use or any current surge at all as might be expected with big capacitance - a full train of ten coaches with flickerfree will draw less current than one sound equipped OO scale locomotive.
Any form of power pickup is acceptable, live axle, wipers, whatever you prefer.
There is no "Fault" with the system. The unit takes a few seconds only to reach full charge, and once that is done there is NO variane in brightness at all - power on or power off... You can even lift the coach off the track and depending on how many LED you have installed, it can stay lit for up to one hour.
QUOTE (double00 @ 15 Mar 2009, 03:45)
<{POST_SNAPBACK}>Will this system apply to DC 00 gauge model coaches?
How does the power required picked up? Only coaches adapted for lighting, use a sprung metal leaf located between the bogy wheel axles. Fleischman coaches in some instances use this method.
I am made to believe that this system require bogy wheels are insulated on on wheel to enable the correct polarity voltage to be picked up. A fault is that the LEDs vary in brilliance according to voltage applied to the rails feeding the locomotive/coach - as stated a suitable capacitor is essential to give a flicker free lighting within the coach while in motion.
