What methods do members use to secure track to baseboards and underlay?
I have glued cork underlay to baseboards then either glued or pinned track to the underlay. This works, but pinning can deform track or let it twist whereas gluing makes it sort of permanent.
Idealy I'd pin the track with big pins and then add ballast right away then remove the pins, but I'd like to run the trains a bit in the underlay to make sure that I'm happy with the layout design.
