Firstly you must remember to programme the accessory decoder via the programming track / output!
The decoder is suitable for FMZ and DCC according to the NMRA standard. Using this module, 4 points or 4 signals or equally 8 uncoupler tracks, can be connected into the TWIN-CENTER 6802. The module can be simply manually coded to any address from "1" to "119" not previously occupied by a digital FLEISCHMANN locomotive (FMZ-operation). Using the eighth switch, it can be switched to DCC operation. Using the programming according to the DCC standard, the DCC addresses (from "1" to "500") as well as the output capabilities (impulse, continuous or flash operation) can be electronically determined.The output capabilities are equally valid for FMZ operation.
60134
