Fleischmann HO 4305 Edelweiss
3412 Views 9 Replies 3 Participants Last post by  Andy pandy
Advice please I would like to fit a decoder to my fleischmann 4305 Edelweiss has this been done not a lot of room.
1 - 10 of 10 Posts
Some resources on the net suggest that a Zimo MX631 fits into that loco. The current version of that decoder is the MX634 with wire harness (no plug). Sounds like it will be a soldering job.
Problem is I am getting a reading across the 2 terminals on the motor and across right and left wheels? and running fine on DC.
If the loco has an older pancake motor, it may either need a new motor shield (if the shield is completely made of metal), or it may be possible to break some of the conductors to make it suitable for a decoder. A German forum post I found suggests that the 4305 is of the latter type.
This image might help: http://www.hp-pfeiffer.de/digi_umbau1/dcc/..._flm_218_01.jpg
The dark red arrow to the left indicates a contact that needs to be severed. The green arrows up top show RF capacitors that should be removed. All the other arrows show the colour of the decoder wire that needs to be soldered there.
This image shows different Fleischmann motor shields: http://www.hp-pfeiffer.de/digi_umbau1/flei...orschilde01.jpg
If yours looks like one in the leftmost column, then it will need to be replaced. If it shows up in the middle column, you should be able to use the method of severing contacts.
https://www.flickr.com/gp/[email protected]/0BFMHa hope this works I have put a photo of the motor on here regarding connection of a decoder.
You can get the 430073 with dcc sound factory fitted, so it must be possible.
A few years back I had both my Fleischmann 4033's converted to DCC sound, and although they run OK, I felt they never ran as good as when they were DC only
QUOTE (Andy pandy @ 13 May 2020, 19:30) <{POST_SNAPBACK}>https://www.flickr.com/gp/[email protected]/0BFMHa hope this works I have put a photo of the motor on here regarding connection of a decoder.
Doesn't work for me, I just see a message saying you don't have any public photos.
QUOTE (alanoes @ 13 May 2020, 22:01) <{POST_SNAPBACK}>You can get the 430073 with dcc sound factory fitted, so it must be possible.
4305 was made between 1971 and 2002. 43007x models were first made in 2016. They probably have quite different interiors. 4306 (from 2003 on) had a 6-pin digital interface, but 4305 was purely analog.
Fixed the picture now it is on the the right the other pictures is post I have on here about a Trix crocodile.
Look, I'm no expert with these motors. But that looks like it's metal without any conductors on it. In the overview from Pfeiffer it looks like it's 504702. So you may need to replace it. Part number 504730 may a suitable replacement part for this. You can still find those on eBay.
This link might also help a bit more: http://mainlyfleischmann.blogspot.com/2013...plate-info.html
Thanks thats very helpful looking on eBay the replacement part is £15+£15p+p then the price of the decoder not as easy as I thought.
1 - 10 of 10 Posts
