Opinions on this set of circumstances would be much appreciated.
I recently started building a layout using FLM DCC kit with a Twin Center controller. I have three locos, two new fromFLM and the third a second hand FLM, from Germany, which has had a chip (6876) fitted in the UK. Prior to the using the second hand loco, no problems, running lights on as required and very smooth.
Since I've started using the second hand loco the running running lights, on any loco, only come on when on even numbers on the power controller, on odd and off the running lights are off, however of more concern is stopping this loco. On ocassions it will stop when contol returned to zero and on others it runs on up to 15cm. A pain when shunting into sidings and has resulted in minor damage to stock. My original 'new' locos continue to work well and stop when zero selected on controller. The only minor issue with these is that of the running lights.
If anybody can shed light on what is going on I would be grateful.
Many thanks
Nigel
Many thanks
Nigel
