1 - 20 of 46 Posts
QUOTE (Doug @ 27 Feb 2007, 12:59) <{POST_SNAPBACK}>The blue will go...
that is the default. I'll be sorting the skin out ASAP.
Oh I don't know, I quite like it. I'll just have to work out all these new bits.
Discussion Starter · #4 ·
[Aw Doug, the blue is nice. If it was pink well!!!!
Ozzie21
quote name='Doug' date='27 Feb 2007, 23:59' post='23124']
The blue will go...
Please see here.
[/quote]
· DT
As you can see, we're upgrading the forum with the latest version.
The big thing that you will notice is the skin doesn't quite fit. It's is easier to convert the new forum and modify the sking to our old look than it is to take an old skin and try and make it fit the new form as there are quite a few changes.
So please bear with us over the next few days and hopefully things will get back to normal soon.
· DT
I'll get the other colours back in a bit.
BLOGS
I've upgraded the Blogs system.
Please report any errors.
For Blog users, skins have been reset to the default. The old ones had too many discrepancies that would have taken too much time to sort out.
When the new skins are ready, I'll add them and you can select them again.
Regarding skins, I'll leave this blue as an option and put back a yellow / orange one as the default.
QUOTE (Gary @ 27 Feb 2007, 17:00) <{POST_SNAPBACK}>The colours! Yuch!
Clearly we are having a blue and light beige moment.
Happy modelling
Gary
And alternatively coloured posts!!
Wheeee!! Isn't this fun
· DT
9 hours later and the upgrade is done. The size of the upgrade required all files to be changes. Skin files (which determine the look and feel of the board) had to be modified from the new files. We couldn't take the old ones and make them fit the new. So there will be a few changes to what you had before.
The Orange is the default and is what any guest or new member will see. Blue is available if you want it. I'll see what the uptake is and decide to keep it or dump it later.
Do members want customisable locomotives up at the top, an image that changes from time to time or a fixed image?
The editors have been revamped. Should be better.
Images were automatically resized. I disabled this as it was resizing my 700 pixel wide images. I didn't think that 700 was too wide. I'll play around with those setting later, but as long as members keep images to a reasonable size, then we won't have to turn on that feature.
I'm discovering new features of version 2.2.2 at the same time as you are. If you have a problem, check out the 'Help' at the top of the page. Otherwise, please don't hesitate to ask.
The forum should be a little more stable, faster and laid out in a more logical manner.
1 - 20 of 46 Posts
