QUOTE (N Gauge James @ 23 Aug 2008, 11:02)
<{POST_SNAPBACK}>Hello all,
I'm new to making buildings from scratch and am experimenting all the way. The results have turned out well so far - except for where it comes to gluing painted surfaces together.
I use poly cement with no trouble at all for unpainted sheets, but that attacks the paint (Plasti-kote). Is there something I can use that won't do this?
Hi James,
Poly cement will attack all paints, i would presume you mean the liquid type cement ? and not the tube material.
Plastiweld liquid cement from EMA is the ideal for plasticard sheeting or plastics, though this will still attack the paint a better solution would be to assemble the building (sand level off an areas if need be) and then paint it as buildings painted individually and then brought together always present this problem, if assembled and then painted any areas needing attention can be corrected before the painting stage saving on touch ups later
Also the thing to remember is the cemented joint is only as strong as the paint adhesion if assembled after painting and so the best way is to assemble and then paint.
The plasticweld is best used bringing both parts together and then with a brush applying a small amount of plasticweld on the joint letting capillary action do the rest in this case applied on the inside of the building where the joints meet.
You should be able to buy Plasticweld at your local modelshop .......
http://www.plastruct.co.uk/shop/prodpages/page-PPC-2P.html
