1 - 11 of 11 Posts
I ordered a GT3 at ailsbury and it arrived a couple of days ago. experience has told mee that you really need to grab curiosities like this when they come around or you may never see them again. i love the unusual prototypes.
The castings are generally pretty good. there are a few bubbles along the bottom of the chassis valance. the cab and tender are both very nice. the only real weak spot is the intake grill. i dont think i can live with the supplied one and i'm going to have to etch a replacement.
It needs a hornby class 5 chassis but i may go for a comet instead.
I'm really not very good at getting loco chassis to work smoothly but i have been looking at the jig from hobby hollidays. it looks like a really nice piece of kit and would certainatly help me to get evrything square.
http://www.hobbyholidays.co.uk/masterchassis.htm
· garage hobbit!!!
Good luck with this one Peter, I also like yhe GT3
Look forward to seeing pics as you progress
Brian
QUOTE (pedromorgan @ 15 Jun 2008, 15:36) <{POST_SNAPBACK}>I ordered a GT3 at ailsbury and it arrived a couple of days ago. experience has told mee that you really need to grab curiosities like this when they come around or you may never see them again. i love the unusual prototypes.
***Peter, I think you undersell yourself - you are excellent with an Iron and have all the other tools you need to make a square chassis - its just technique you need to add.
* Read Iain Rices book on loco construction for "can do" inspiration.
* Get a square of clear glass to build the chassis on.
* get a couple of say 200~250mm lengths of 1/8" silver steel rod (the same stuff loco axles are made from)
* place the glass on one of those gridded green hobby mats.
* Carefully ream axle bearing holes only enough for a smooth sliding fit of the bearings.
* Mount the bearings in the chassis sides before you assemble the chassis.
* Use the silver steel rods through the bearing holes and make sure that when the chassis sides are parallel with one axis of the grid, the silver steel rods are parallel with the other grid axis.
Thats really all U need to keep it square - the glass for vertical squareness and relativity of the two sides and the frames and silver steel rods vs the grid of the modelling mat for geometrical alignment.
The jig you are looking at is certainly an impressive bit of kit but its my experience that such things are "crutches for the skill challenged" and not the answer to "walking properly".
I've seen more than enough of your work to know you could do it well without the prosthetic help!
As the Nike adverts said "Just do it"
I know what you mean richard. but how come i always make such a complete pigs ear of it??!!
i have 2 loco's that i am very proud of that are basicaly finished except that one wobbles like its doing the time warp after 6 pints and the other where no matter how hard i try i just cant get the 6 wheels running freely with the con rods on.
My first steam loco kit was a garrett (stupid i know!!) which actually runs ok. except that it grinds to a halt with more than about 4 wagons on the back!!
Next came lion.
I thought i had improved and i wanted to have a go at outside frames! (big mistake!) the trouble was that with outside frames you looke the inbuilt quatering that you get with romford wheels. maybe a quatering jig would sort it out. but having come down from a garrett, failure to get 4 wheels turing freely was a real downer!
And finally came the W1. i was thrilled with the way the body went together. i realise its not quite square but neither are the castings. and its good enough for mee. but the chassis was a complete nightmare. i tried about 20 times to get the 6 wheels running freely. my motor and gearbox runs nicely but as soon as i put the conrods on the whole thing suddenly aquires 20 units of alcohol!
I have a turbomotive chassis waiting for me. but i dont really want to touch it untill i can get the W1 working properly.
QUOTE (pedromorgan @ 16 Jun 2008, 13:46) <{POST_SNAPBACK}>I know what you mean richard. but how come i always make such a complete pigs ear of it??!!
Next came lion.
I think I know you well enough to say with the best of intent "because you gave up on them", not because they couldn't be tweaked into life :)
However its not easy to fix many issues without a bit of awareness about what is causing them and I suspect that most of the problems are due to kit part error and not in any way "peter" created - so be confident!!! I've built two of the locos in your pictures + the turbomotive and in all cases, I threw away much of the chassis and associated parts as they were manifestly rubbish!
The thing that ALL of your problem loco's have in common is that
(1) the chassis were machined or cast not etched
Or
If etched, they were created when artwork for etching was all hand drawn and then scaled with a camera - and when thats done only a master of art/photography & etching ever gets the mfg process perfect.
The common problem was that not only did the art contain lots of slight errors, sometimes the bearing spacing for the left chassis half was slightly less accurately positioned than the right chassis... and to compound this, the connecting rods also often had slight errors for their relative hole positions... so without very careful tweaking to to get these critical things right they never run well.
The way to check this and get it right is to first check that things are reasonably OK with a good quality micrometer etc then build the chassis using the method I described.
Then.
Have a set of jigs for the connecting rods. these can be sliver steel axles turned down to a long slightly tapered pin at each end (which matches say a romford/Markits crank pin in diameter at the halfway point).
Put these through the axle bearings. Both sides connecting rods should slip on nice and smoothly if the axle holes and the connecting rod holes are actually in the right position. recheck by then placing left rod on right side to make sure both sides are the same.
If not you will see the errors.
Make sure all 6 wheels sit properly on the glass sheet.
Once wheels can all turn freely and the connecting rods all fit smoothly, if you've used Markits wheels then the square ended axles will guarantee perfect quartering and the chassis will run smoothly.
to test this now put the crankpins in the wheels and put the wheels and axles onto the chassis. Slip the connecting rods on the crankpins and hold them there temporarily with a wee bit of insulation tube stripped from some wire.
If there are any tight points then enlarge the offending hole left & right a wee bit but NOT up and down (make it a flat oval not a larger hole)
To fix your current loco's. Most of your current prroblems aren't you - they are the crappy chassis, parts, wheels and motors supplied with those ancient kits.
For bad wheels (old K's kits in particular). Chuck the driving wheels out and use Markits wheels and axles.
For all old kits - chuck the gearboxes and get some new ones from Hi-Level Kits - they are sublimely smooth.
For the Garratt and anything with an old motor - the K's motors are especially rubbish - replace with Mashima - preferably one each end on the Garratt.
For possibly wonky connecting rods. Get a couple of sets of Gibson "universal connecting rods" - these are in several parts and can be made up in different lengths. build them up with precise spacing on a jig made from crankpins set into an alloy or wood block.
For the turbomotive - Just dump the K's chassis and get a princess chassis kit from Comet. Turbomotive = Princess to all intents and purposes.
PS: Re the LNER Hush Hush... If you don't mind the positive suggestion.... get rid of all the whitemetal boiler bands totally and replace with scotch tape bands (the cloudy looking sellotape stuff - put a strip on glass and cut the bands with a new scalpel blade). They really do stick fine and definately won't lift after painting is done.
Those ugly whitemetal bands are twenty times overscale....same applies to much cast on whitemetal detail and definately all whitemetal boiler bands really - garratt included.
Also... If the kit "as bought" wants you to use a screw each end to fix it modify it so that the chassis is captive under a lip or similar one end with only one screw the other - If you do as they say & use a screw each end, its very easy to slightly twist the chassis and running always goes wonky when that happens
· In depth idiot
Peter,
Glad to see you seized the opportunity when you saw the GT3 kit, doubtless in common with many others here I look forward to seeing the finished model.
Three thoughts.
Does the kit specify a Hornby black 5? The prototype was built on a BR standard 5 chassis IIRC, and that might make the chassis for that a better choice in terms of fidelity.
I concur with Richard's advice. When it comes to a kit chassis you have to take nothing on trust, but measure and modify to obtain a runner. Doesn't matter what materials or techniques have been used to produce the parts, it is all down to builder to do the necessary quality assurance. Just one benefit you obtain is that once you have the experience of the necessary principles it is transferable: now you can confidently buy that nice looking poor /non-runner for a very low price, knowing that it can be made into a satisfactory machine.
So definitely worth investing in the 'how to' of kit chassis building, but only in my opinion when there is no good RTR alternative, (provided of course that RTR meets your modelling standards). This last purely on cost grounds: price up what the etched frames, wheels, crankpins, motor, gearbox, rods and gear will come to. It will likely be more than buying the complete RTR model, and you can sell the unwanted components from the RTR item to reduce the price further. As an example the chassis from Hornby's Railroad A3 or A4 will make your W1 a runner for £50 outlay and a couple of hours adaption work.
QUOTE a good quality micrometer
That reminds me of the first time I realised what a difference one thou made when it came to metal working. Drill a hole 3.999 in size and there is no way on earth that you will get a 4.000 rod to fit in it. It opened a whole new perspective I had never considered having never had the benefit of woodworking or metal working classes.
QUOTE (pedromorgan @ 15 Jun 2008, 08:36) <{POST_SNAPBACK}>I ordered a GT3 at ailsbury and it arrived a couple of days ago. experience has told mee that you really need to grab curiosities like this when they come around or you may never see them again. i love the unusual prototypes.
Strange - I was only looking at this at Chatham on Sunday and thinking about getting one, but in all honesty I could not justify it.
It does look nice though.
Discussion Starter · #10 ·
Hello folks
Thankyou all for the advice. i have taken it all in.
QUOTE (Richard Johnson)I think I know you well enough to say with the best of intent "because you gave up on them", not because they couldn't be tweaked into life :)
Hello richard.
after the garrett and lion i invested in the branchlines chassis building jig but although it does hel to allign the axle bearings, it dosent help with the crankpin holes on the connecting rods.
I have always used markits/romford wheels but i have trouble getting them square on the axles. (i dont mean quatering i mean getting them running true when they are on the axles.)
I have always used branchlines gearboxes but i find they are a bit rough and sound like a number 17 bus. i will try the high level ones. i understand they use helical gears. i asume thats the main difference.
I havent decided on the whitemetal boiler bands. i definatly dont want to keep the whitemetal ones but people keep telling me about a tape they ise in aircraft modelling that has a metal finish.
For turbomotive i have a comet chassis sitting waiting but no wheels for it yet. its actually a dean sidings loco not a kays. the castings looke very good.
QUOTE (34C)Does the kit specify a Hornby black 5? The prototype was built on a BR standard 5 chassis IIRC, and that might make the chassis for that a better choice in terms of fidelity.
The kit specifies a class 5 chassis.
thanks for the advice on the RTR chassis. i may well do as you say with the W1. after the garrett and the lion i had a loco that had a huge cavernous boiler and i wanted to make the most of it by fitting a huge motor. unfortunatly i then got the problems with allignment.
I have an O gauge chassis to do soon and i have an eye on a backwoods minitures 009 Darjeeling B class!
QUOTE (pedromorgan @ 22 Jun 2008, 05:21) <{POST_SNAPBACK}>Hello folks
Hi Peter
Did you ever finish the GT3?
I am thinking of buying the Golden Arrow OO kit.
Ray
1 - 11 of 11 Posts
