QUOTE (hoarp001 @ 2 Sep 2007, 15:03)
<{POST_SNAPBACK}>Hi,
Before I started to scene the main layout, i decided to do a mock section of track. Its a bit of MDF with a straight bit and a curve of track, and a hill side. I mounted the track down on 1/8th cork and pinned it down. I managed to get the middle of the track looking brilliant, but then I did one of the sides and the excess ballast flowed over the top of the rail and screwed up the middle! Very annoying.
After about an hour I managed to get it all looking pretty good, but when i sprayed it with the water, then water and glue the spray blew some of the balast away and ruined it!
Any tips for me? Any instructional videos I could watch?
Thanks very much,
Pete.
I still like the wallpaper paste and ballast miixture method.Never was keen on using white glue mixture and eyedropper method.
I spray my track after masking point blades with brown Krylon Camouflage paint system which gives a non-reflective,ultra flat finnish.It is a good grubby brown colour to use as an overall base before you do touch up work.
After all is dry I mix about one third or more Lepages Poly Stick Fast Wallpaper paste powder with two thirds ballast gleaned from Cordova Bay beach here and it looks like the Gaugemaster ballast shown in pictures in this thread.
It is very fine and requires a wash and dry.
I use a fine mesh strainer to get a consistant size ballast.It's coulour is a greyish with black an white mixed in.Volcanic in origin I think.
Also it is free!
I then sprinkle the ballast and wallpaper paste powder mixture on the track and tidy up with a ladies make up brush.
With a very fine misting spray bottle with a couple of drops of washing up liquid in warm water I spray the ballast gently giving it a good soaking.
Giving several light pases with the spray at first prevents any puffing away of ballast.
I use a cardboard mask to prevent overspray.
When all is dry and it does dry quite hard enough,then with a fairly stiff brush,brush off any excess ballast and vacuum.
A dental pick from your friendly dentist is also very handy for fine tuning.Mine is very obliging with the old ones no longer of use in the surgery.
Any mistakes can easily be rectified using plain water.
Clean up is also very easy with plain water.
I have tried the white glue method but found that it dries rock hard.
This makes it difficult for one to change ones mind regards re-tracklaying etc.
I am not sure if it would soften after wetting or not.The white glue they sell here is waterproof.
With the wallpaper powder method it is readily sofened with a spray of water and the track can be lifted easily and recovered,taken outside and washed with the garden hose.
For me this seems to be the best way of ballasting but then everbody has their own way of doing things they find the best.
Happy ballasting!
Bryan.
