2 stations or 1 plus a sidings / refuelingHello!
Wondering if the much wiser among you might care to point out any gotchas in my design, or anything that doesn't seem "right"?
It's based on Don Culp's Havaphew Central (hence the title of this post,) a layout that I instantly fell in love with, even more so once I saw the accompanying photos of the completed layout and how he'd gone "big" in a small space.
I don't think I will be going "big" to the extent he has (with the large town buildings,) but I am toying with a north-south divide along a road in which the north side is pretty rural/countryside and the south a little more built-up, since I plan on having a (relatively) large passenger station there, as well as the turn table.
Obviously I've tinkered with Don's design quite a bit, and mine is larger, and also I will be modelling British era 5 using Peco code 55 throughout (N), and it's DCC. The few buildings/stations/road are just there to give me some idea at the moment, especially regarding clearances and what will fit; nothing is absolutely set in stone yet.
Anyway, without further ado, here it is:
The things I wonder about are:
1. In the sense of avoiding S curves, will the wye at top left cause issues for the incoming branch? (It's there to save space.)
2. Is the curved point at bottom left OK there? (It's there to save space.)
3. Are back-to-back double slips problematic? (You got it: there to save space!)
4. The sidings just beneath the larger station on the right: There'll be some kind of small industry there, but are those crossover points in the right direction? They're intended for a loco to uncouple and reverse out on the adjacent line, but since we're "driving on the left", I'm not sure if it means that those points really should both be left-handed instead. (I've chosen their current orientation based solely on the length of the lines.)
5. I've purposely tried to make it impossible to go from the outer loop into the inner loop without a train reversing, to prevent trains colliding head on. Have I done that "right"?
6. The four "legs" (lines) leading off at the four corners are intended for any future expansion, because I can already see the need for a fiddle yard or at least another destination for trains. But I don't want to get ahead of myself just yet.
7. I did wonder about the separation between the lines on the left curve, but that's been answered in another post, and I'm reasonably confident that it's sufficient.
I guess you guys may wonder about many other things too! But please be gentle, it's taken me nearly a year of tinkering to get the design to this stage.
Thank you!
options for track ends
turning point and storage
curves
a road that goes somewhere so shops / houses
got a number of options I like it
IF you then had a trade in and out station and a trade in and out era / geographical set of locos, you could have two for one, and loads of general generic kit
i llike it
