Heljan model 27.
6514 Views 36 Replies 11 Participants Last post by  7113
I note Heljan have several types of model 27 on the modeling scene!
What is the best one to buy? "Green or Blue BR" livery or?
1 - 20 of 37 Posts
Surely it would depend on which era you were modelling, and what sort of duties you intend using it on.
I have no special decade in my modeling needs and at present concentrate in passenger services.
In fairness I must confess that my modeling habits are strictly, for enjoyment in running any locomotive (diesel) that is easily controlled and appeals to me.
Not all RTR models are manufactured to the same degree of quality - my preference to Heljan is number one. Their models have the feel of sturdiness whilst handling, quiet in running and most reliable.
My reason for posting topic, is simply not being able to afford to buy all of the 26&27s models offered by Heljan - is there any preferences by other modelers, though in the end it will rest as to my choice.
I have a green 27 and it runs perfectly. Very impressed. This is my first heljan model and i will certainly be going back for a blue 27 and some of the unnumbered 47s when they arrive.
One thing to watch out for in the 27. It has a sealed nose door. This means the green one actually has a very short time frame, probably 1965-1968, whereas the blue ones would be longer lived. At the end of the day its whichever period you model that counts.
Whatever you choose I can recommend it. Just don't put a Hornby decoder in it if going DCC
Russell
rb277170 - thank you for your comments on the Heljan 27 (blue) models.
The majority of my locomotives are coloured "blue" - however it appears class 27 Heljan has at present offered in:
5380 (2701) 27034 (2702) 2705 (2703).
Descriptive information quoted by Heljan and retailers Hattons, reads very similar to each blue coloured model, making a personal choice hard to decide.
double00....you have declared your broad interests.....well done!
Have a look at them all if you can, and choose the one that truly appeals to YOU.
What I also do is check out each [#27] running number offered...and have a look on the net for any really good photographs of the actual loco?
then, if one particularly appeals....you have a clear prototype photo to compare with...plus hopefully, some realistic weathering to refer to?
http://web.ukonline.co.uk/53amodels/ I have found useful...John Turner has a good period range of photographs
(but not the only photographer out there publishing......just one I know of locally)
[He has an excellent piccy of 37414, in the Vitrains #37 range.......very sharp, clear, and full of inspiration for the weathering brush!]
Are there any preserved #27's to refer to?
Well doubleOO you have declared your interests which makes me think the best colour for you would be one of the blue versions, it's the only colour I ever saw one painted! (Crewe works open day 1974)
QUOTE (rb277170 @ 1 May 2007, 02:38) <{POST_SNAPBACK}>Just don't put a Hornby decoder in it if going DCC
Russell
I also want to buy a Heljan 27 but for what reason not to put a Hornby decoder? any other recommendation?
Thanks,
Dennis
QUOTE (ms06s_char @ 7 Jun 2007, 08:20) <{POST_SNAPBACK}>I also want to buy a Heljan 27 but for what reason not to put a Hornby decoder? any other recommendation?
Thanks,
Dennis
For the same reason not to put remoulds on a high performance car !
Seriously though, go for something like a Lenz Gold/Silver, ESU Lokpilot or the equivelent from any of the manufactures who specialise in DCC & not trainsets.
QUOTE (dbclass50 @ 7 Jun 2007, 15:45) <{POST_SNAPBACK}>For the same reason not to put remoulds on a high performance car !
ok....so only use Hornby DCC on low end locomotives, like Bachmann and Hornby? I currently only have a Hornby Class 50 fitted with a Hornby DCC controlled by the Hornby Select unit, now thinking to expand my fleet......like a Class 101 DMU from Hornby, Class 45 + Class 25/1 from Bachmann and a 27 from Heljan.
Dennis
QUOTE I also want to buy a Heljan 27 but for what reason not to put a Hornby decoder?
I have read that some Heljan models take a lot of power (current). If that is the case for the 27, the Hornby decoder will not be strong enough to deliver the current the Heljan needs under load.
Perhaps someone could tell us what the power consumption is for a Heljan 27?
QUOTE For the same reason not to put remoulds on a high performance car !
unless they're made by Colway tyres, of course...........in which case, I'd be happy to fit as long as the speed rating was correct....they might prove a better choice than many 'new' products?
{ask anyone who enjoys competing in rallies?}
QUOTE (alastairq @ 8 Jun 2007, 20:50) <{POST_SNAPBACK}>unless they're made by Colway tyres, of course...........in which case, I'd be happy to fit as long as the speed rating was correct....they might prove a better choice than many 'new' products?
Fair comment - but they don't have to last that long in any motorsport !
Brian (ex Rally Driver).
Surely using remoulds for rallying has a bit to do with cost? Anyway they're perfect for rallying as any tyre imperfections can counter the fact that the wheels aren't likely to be very round.
QUOTE (dwb @ 8 Jun 2007, 01:41) <{POST_SNAPBACK}>I have read that some Heljan models take a lot of power (current). If that is the case for the 27, the Hornby decoder will not be strong enough to deliver the current the Heljan needs under load.
I tried to fit a Hornby R8215 on a Heljan class 27 but it doesn't work properly....the lights are blinking when the loco is in motion....and sometimes not respond well and stopped and then it runs like a bullet train that cannot be stopped! What's the problem? the decoder hasn't got enough current? should i get a more powerful decoder? please name me some. +I use the Hornby Select unit.
Thanks,
Dennis
Just a note to say some really good bargains at Hattons on heljan 26 and 27s. I got 27105 for £54, although I note they are now out of stock of this particular locomotive.
New releases of 26 and 27s coming. However there don't seem to be any new TOPS numbered 27s - so anyone wanting one would be advised to buy a blue one now.
Russell
I find when running my Heljan 27, that the power controller setting is the same as all of my other locomotives. However my layout is not DCC.
QUOTE (double00 @ 22 Jun 2007, 06:06) <{POST_SNAPBACK}>I find when running my Heljan 27, that the power controller setting is the same as all of my other locomotives. However my layout is not DCC.
what's the output rating for your power controller?
the transformer that came with the dcc controller is 15V 1A, I tried running Heljan 27 in analogue mode, the lights were blinking too, may be the loco is a decfective?
I found out that the Hornby decoder's output is quite weak, just 0.5a for motor while Lenz Gold/Silver is 1A
QUOTE (ms06s_char @ 21 Jun 2007, 17:07) <{POST_SNAPBACK}>I tried to fit a Hornby R8215 on a Heljan class 27 but it doesn't work properly....the lights are blinking when the loco is in motion....and sometimes not respond well and stopped and then it runs like a bullet train that cannot be stopped! What's the problem? the decoder hasn't got enough current? should i get a more powerful decoder? please name me some. +I use the Hornby Select unit.
Thanks,
Dennis
If the lights are blinking in time with loco faltering the problem is almost certainly a pickup one. DCC requires an uniterupted supply/signal, therefore clean track, wheels & pickups are essential. (Although locomotives may run OK on DC you won't "get away" with it on DCC !).
Check the track for dirt (don't assume that because it looks clean it is clean), the wheels & all the pickups. If you have a multimeter check that you have a circuit between all the wheels on each side.
Some locomotives have a coating on the wheels from new that can cause pickup problems until it's worn off - if this is the case run the locomotive in using plain DC on a test track if possible.
If you don't have a meter then Maplins start with a basic one for £9.99 cat no UZ82D & go up from there in specification & price. They also produce a useful booklet called "Getting the most from your multimeter" catalogue no.WP94C
Once you have done that try again, but I suspect the the Hornby decoder may not be up to the Heljan motor. Do your locomotive justice by fitting something like a Lenz Silver/Gold or an ESU Lokpilot - we have had good results from these. Other members favour Digitrax & TCS to name a couple & these are all worth a try.
Some decoders do not work very well with the Select but as far as I know Lenz & ESU are OK.
Hope this helps.
ps - just read your other post - this seems to confirm a pickup problem !
1 - 20 of 37 Posts
