QUOTE (welshdiesel @ 14 Jun 2008, 17:52)
<{POST_SNAPBACK}>has anyone tryed to convert the lima warships to run on dcc and if so is it quite easy, your help is greatly welcome
a new dcc modeller
I have not actually converted a Warship loco, but I have done class 156 DMU, 121 DMU all of which use a very similar motor. I use a Bachmann function 3 decoder. You only need to use the Orange & Grey wires which connect to the motor terminals, and the black and red which connect to the pickups. Apart from the class 67, the above will work on all Lima "Pancake" motors. One tip, I strip the motor down, make sure all the gears are free running (they are not always and sometimes need the hole opening up very slightly in the gear wheels so they are not tight on the pivots). Remove all the grease on the gears and just add plain model lubricating oil in place of the grease. You should get much better running after that. Hope this helps.
