1 - 1 of 1 Posts
Administrator
Rectangle Amber Font Flag Electric blue
Plant Car Vehicle Property Building
Font Rectangle Brand Automotive exterior Logo
Gadget Font Input device Audio equipment Electronic device
Access One Handheld IR Controller
Features:
  • Will connect to both the Select and the Elite.
  • Able to programme loco numbers, acceleration / deceleration levels, consisting and functions control.
  • Incorporates single rotary controller.
  • Large 4 figure LCD
  • IR capabilities - wire free. Wide signal spread.
Vehicle Line Measuring instrument Gas Audio equipment
Hornby Elite, now NMRA Compliant and certificated
Font Emblem Circle Symbol Automotive wheel system
Circuit component Passive circuit component Hardware programmer Electronic component Font
Sapphire Decoder· Built to conform to all relevant NMRA Standards - as listed in specification item
GS001
· High frequency back-emf motor control - high frequency to reduce audible noise
· Supports RailCom. Asymmetrical DCC support
· SUSI Sound Interface
· Size: Length 23mm x Width 16.5 mm x Height 6.5mm - estimated.
· Low speed gear for shunting operations.
· 14, 28 and 128 speed steps.
· Optional operation on conventional DC layouts
· Provides 1A continuous motor current, 1.5A stall.
· Four function outputs rated at 200mA each - further functionality can be driven through the SUSI interface. Total current sum of function outputs = 500mA.
· Directional or independent lighting with dimming and extensive special effects.
· Supports advanced consist control and extended addressing.
· Support for programming on the mainline (operations mode programming).
· Support for all form of programming as described in NMRA RP-9.2.3
· 21-pin connector.
Sapphire Mini Decoder
· Built to conform to all relevant NMRA Standards as listed in specification item GS001.
· High frequency back-emf motor control high frequency to reduce audible noise
· Size: Length 23mm x Width 10 mm x Height 4mm estimated and to be confirmed.
· Provides 0.5A continuous motor current, 1A stall.
· Four function outputs rated at 200mA each further functionality can be driventhrough the SUSI interface. Total current sum of function outputs = 400mA.
· 8-pin connector.
Advanced Features
Set amounts of "water and fuel" can be stored in the decoder which will enable Simulation driving. Burn rates can be selected. The locomotive can start / stop based upon Asymmetrical DCC input or clock without input from the controller.
Different lighting effects can be set at the four function outputs:
- steady state
- strobe
- flickering / random fast flash
- flashing including Marslight, Gyro etc
Office equipment Electronic instrument Gadget Font Laptop accessory
Accessory Decoder
Features:
  • Incorporates 4 outputs.
  • Each output adjustable for variable current flow.
  • Suitable for flash or motorised point motors
  • Ideal for turntable or motorised accessories plus lighting
  • Surface or below baseboard mounting
  • Complete with screwdriver, mounting template and power clip
  • Size: 60 x 100 x 25mm
Train Wheel Vehicle Green Nature
East Coast Pullman
Contents: LNER B12 locomotive, LNER J52 locomotive, 3 Pullman Cars,m3 assorted wagons, Select Digital unit, large oval of track with 2 sidings. TrakMat included
Thomas
Live Steam
Hornby Digital
Digital Sound
Train Sets
Train Packs
Steam Locomotives
Diesel & Electric Locomotives
Coaches
Wagons
Track & Control
Skaledale
Skale Lighting
Skale Autos
Skale Scenics
Railroad
1 - 1 of 1 Posts
