iam planning on getting a new dcc ready class 59. to put my National power body on. with a dcc ready loco is it still poss to add lights?. if so could someone give me some hints on how to do it?.
QUOTE (john woodall @ 25 Sep 2008, 10:38) <{POST_SNAPBACK}>With DCC its not hard by using one of the function wires to power them.
Choice is yours as to using bulbs or Leds. My personal preference would be leds.
hi John,
thanks for the reply. do you now where i could get info on how to wire?. have not done lights before and i dont want to damage the chip or the loco by guessing. Is there any web sites you could recomend?
I'd also like to know this. I've got an ARC 59 and Medite 66 (they seem identical to me) and would like to add lights to them as per my Bachmann 66.
Pepe007 - do you have any Hornby 59 or 66 already chipped? Only ask as per my thread I've had a few issues with slow running.
edit - a quick google shows express-models as having lighting units for these locos but for 4 pin decoders?? I've emailed them to ask if there are light units for these locos that will work with Bachmann 8 pin decoders.
Here an N gauge installation using a four function wired decoder the green wire was taped down not being used after the picture was taken.
use LED's though bulbs give off heat over time possibly melting bodies.
Keep the light directional and no overspill by putting heatshrink over the LED only giving off light to headlights and not the cab interior, the loco above has had this done.
thanks everyone
francesco
***Simple instructions to add lights:
The "blue-white" look of standard white LEDs available generally at Maplin etc looks horrible in a loco.
Use "Prototype white" LEDs from, for example, Bromsgrove models. 3mm would be right for a simple install in most OO scale.
you need a 1k resistor in series with each LED, these are provided with the LEDs from Bromsgrove.
Nicks advice to add shrink tube is good, but make sure it doesn't stop the LED entering any headlight hole in the body. Not too much heat on the LED body either - they don't like it!
White wire = front light negative
Yellow wire = rear light negative
Blue wire = common positive for all lights
Front lights:
White wire to the negative lead of the front LED (this is the shorter LED lead)
Blue wire has the resistor in series with it. The Blue wire goes to the long positive leg of the LED
Rear Lights:
Yellow wire to the negative lead of the rear LED (this is the shorter LED lead)
Switch lights on and off with finction ZERO (Or "lights" button on the controller - this is also function zero)
They are set up as auto reversing by dfault when you get the decoder - no need to adjust any CVs
Model Railway Forum
