***As I have said often, real modellers never count rivets, they just notice when they are missing.
Patrick, I really don't mind or care at all whether you are worried about detail or not.... nor do I think you should change if you do not want to... nor do I imply any criticism of you those who run models out of the box.
The fact is that many modellers
do evolve and grow to like getting it right and adding to the quality of what is available off the shelf.... and in this case as all others where I bother to respond in a similar way, it simply happens that I (and subsequently DWB) replied to a post from a modeller who DOES care about relevant detail, with quite relevant information.
... so you'll give up the hobby if detail becomes an issue?
That is your choice but its a truly silly statement, because nobody will ever be bothered to force you to adopt a finer scale approach - we are all too busy enjoying the hobby in our own way.... and our way is only for volunteers who enjoy it
... But don't expect us to dumb down the online MRF responses to make you happy.... If you have no interest, then surely its sensible to simply stay mute!
Most of us also start out with out of the box models, and some of us then find we enjoy modelling to a more accurate level. That is also our choice and we really don't mind one little bit that you or others see it differently, but we certainly don't need this sort of pettyness every time detail is mentioned.
What is it with some "out of the box modellers" that they bridle and protest any time anyone mentions accuracy or detail related issues... do you feel inadequate or threatened or what?
I put it to you that those who bridle at adding detail are even worse than the leather armpatch armchair-modeller brigade who waffle on and were the cause of the "rivet counter" expression...
QUOTE (patrick draper @ 12 Mar 2009, 02:42)
<{POST_SNAPBACK}>I have not counted the rivets on my Airfix 4f so it may not be an exact model, if I ever get to that sort of detail then I will stop railway modelling and find something else. My locomotives are there to run and pull trains, if they do then I have no problem. Minor detail is just too time consuming.
