QUOTE (34C @ 13 Dec 2008, 18:59)
<{POST_SNAPBACK}>I like 46258. With 70 sq ft grate, mechanical stoker, 300psi and circa 56,000lb TE, but an adhesion factor of less than 3, she would have been like a Bulleid pacific for slipping when starting. But once at speed, the continuous 4,000 IHP that such a grate should have been able to sustain for dealing with Shap and Beattock, would have made running a five hour Euston-Glasgow service practical. What would her BR power class have been: 11P/7F?
*** She did really well after initial teething trouble... I suspect that if WW2 hadn't got in the way, the class might have multiplied.
Here's a well and truly reworked front end to reflect the look of the loco when running, with cooling flap up... and a full RHS.
The loco is a well and truly reworked K's body, Comet tender, comet chassis with dual beam suspension (front bogie linked by a compound beam to the driving wheel beam which links front and centre driver ... easier to do than to describe
. It gives correct weight distribution to bogie and drivers as per the prototype - as a result, it is guided into curves properly by the bogie and in general glides along the track!)
Regards, Richard
