hiya group,
I've been given a lovely hornby pullman coach - named 'leona' Hornbys current catalogue still carries it as a R4162A although mine maybe different as its quite a few years old.
Unfortunately its lost the coupling bit to attach to othe coaches. It has an unusual bogey/coupling set up as when the bogeys turns left or right it pushes a rod (with a screw) in it - in or out. I guess that the coupling hook/connector would be secured by the screw onto this rod. If it helps the bogey has 2 numbers on it L9288 and L9285
If anyone knows where I can buy the coupling mechanism/hook which would fit to this movable rod I would be grateful - or a part number would be great. I'm after 2 of them.
hoping to hear from you
Brendan
Brendan
