QUOTE (train_depot @ 10 Nov 2008, 16:18)
<{POST_SNAPBACK}>.. Do something to make the middle tender wheels less floppy, they seem really loose..
If this were my layout and the only vehicle causing this problem was that tender, and that wheel, I would remove the offending wheel, (or wheels if the loco gets turned and can run either way round on the point) and glue in place a dummy plastic wheel with the flange cut off the bottom. Exactly the way Triang Hornby did it on their old style power bogies. It's a bit crude, but it will work.
QUOTE .. Treat the insulfrogs as electrofrogs and add a polarity switch to the frog. This will be tricky as the point motor is buried under some scenery off to the side and even if I could get to it there wouldn't be enough clearance above it. Also I think I'd have to rip up the track to convert the insulfrog to electrofrog right?..
You can convert the point to switched crossing (frog) in situ, if you are able to cut through the rails at four locations, and solder on and run a wire to a switch. It is a fiddle to do, and you really need a rotary cutting tool and small cutting disc, (and maybe a flexi drive if the point is in a really awkward location,) to make a reasonably easy and tidy job of it.
What you do is cut through the switch rails about an inch from the crossing, and through the rail joiners the other side of the crossing. Fill these gaps with epoxy to ensure that the electrical isolation of the crossing is maintained. Solder a wire between the two crossing rails to bond the crossing electrically, and then take this wire to a convenient location to mount a point motor or relay to switch rail supply, wired to operate either in parallel or sequenced with the point motor operation. (I assume from your description there is no easy way to add a switch to the point motor that operates the point.)
What you then have is a point that still has a dead crossing, but switched as though live crossing, so there can be no short circuit if a wheel bridges the crossing rails because they are always on the same supply side. Lot of trouble to go to if it is just the one vehicle that provokes a short.
