Simon Kohler said exactly that to me over the weekend when speaking to him at Warley about Hornby Digital. This is the email Simon sent to MREmag and it is probably better to use Simon's own words rather than my
own:-
QUOTE Concerning your e-mail, I suspect, although I would need to check to be absolutely certain, that the reason why the TCS decoders do not appear to function correctly is the fact that they may require to be programmed using a different format than the Select uses. There are, in principal, 4 specific programming modes - Direct, Operation, Paged and Register. The Select uses the most recent format, which is Direct, but without receiving the technical spec of the decoders in question I cannot be more specific.
Incidentally, the Elite can accommodate all 4 programming modes.
Finally, both the Elite and Select are NMRA compatible.
I hope the above is of help.
Simon Kohler
The Select console has been designed to act as a cab for the Elite as well as being a stand alone budget console in its own right.
Happy modelling
Gary
