*** Excellent test!
Some comments/questions if U have the time and inclination...
(re the "test")
are they all ESU sound decoders - I ask as US ones have higher current needs normally.
A standing still sound loco should draw between 150 and 300mA max, depending on sound decoder brand & lights that are on. How many can be on the track and active when U turn the set on? After you establish this, also short the layout and see if it will recover with the same amount of loco's on it.
(re the layout)
Overall, a good reason to have areas that can be turned off....
The turn on current will drop when the sound decoders and system stabilise. Therefore as U found, once its "on" it will support more locos than it will start up with - or recover from a short with. Therefore its a good idea to have an ability to turn off chunks/sections of the layout - engine, stabling sidings, fiddleyard etc.... It'll not only mean U don't have to remve loco's, it'll make any possible troubleshooting easier too....
Thanks for the "power test" on the dynamis - so far, most interesting
DCCconcepts
(re the "test")
(re the layout)
DCCconcepts
