Hi All,
I normally use feed the toe of a point with power from the bus use isolating joiners on all four lines coming out of the frog and add four droppers after the isulating joiners.
If i leave a gap between the end of the frog and the following lines would this be sufficient to isolate the point rather then use isolating joiners still wiring as above ? the HO joiners are a little obtrusive if it would work this way i would prefer it.
Many thanks
Many thanks
