Or is the Peco 540 locomotive servicing depot out of proportion?
The coal stage is 2.25" x 2" and the crane span is about 2" span, so no matter where you place it on the stage it hangs right against one edge. The chain-wheel scales up to approximately 7ft diameter. The total lift height adds up to 27ft, excessive?
There are unexplained 'extra' bits, which I'd only complain about if I had a full scrap box, such as a bulkhead light, two sets of duck-boards, a bit of ladder, extra fire buckets and a piece of fluffy ended 5.5mm diameter braided nylon rope which I presume is supposed to be the canvas hose for the water tower. for which I've substituted a piece of 3.5mm brown rubber cable insulation which scales up to about 10" or so.
It's not finished yet, and I know it doesn't look like the one on the box, but I've used my own base for the tower to match some of my other stuff. Your thoughts, please, but is that crane massive?
