Hi. I want to run some wires from one end of a HST to the other, via the 3 coaches in between (wiring for lighting - being cheapskate I dont want to use a second decoder in the dummy cab just to operate the headlight). Although the train formation will always be the same, permanent connections between carriages are likely to be a serious nuisance when rerailing etc. How can I arrange some simple connectors between coaches, so that they can easily be disconnected if necessary?
Thanks for reading.
JD
Thanks for reading.
JD
