Few weeks ago I got Faller kit no 131010 light house
such kits so much plastics appearance.I did some paint works
on it to modify concrete view
simply as below can do same technique for similiar kits such as
concrete buildings,platnt etc.
This light house in Istanbul which was a similiar model for me.
main body sanding with sandpaper 400.sanding from up to down in one
direction we obtain rough surface.
This will perform for easy and good painting also
1-original plastic windows
2-painted with sprey color
3-after drying guache water based color for mat view
4-Mounted them.
1-body mounted and colored by white sprey
2-used putty for holes and connections of the body
Used guache water based white color with mixing 5white+1rawyellow
3-again sanding with sandpaper
4-resin frames prepared and mounted
Again painted with mixing 5white+1rawyellow guache color and black
belt painted
5-motor and light mounted .tested
base made by plaster works and mounted a bit near our port
a.usta
