7-Plank RCH1923 'Convertible' Coke Wagon - Gas Light & Coke Co, Beckton (Continued)
Now for the nerve-wracking part...... the lettering.....
Whilst I have used Letraset many, many years ago, this would be my first attempt at rub-down transfers onto a 3D surface.....
As mentioned before, I am being slightly naughty and applying these transfers onto a 7-plank wagon, where they should be on a 10-planker, so I have needed to make some 'adjustments' to the spacing between certain parts as it progressed...
According to the instructions you should start with the black shading, so this was held in place on one edge with some masking tape, and then carefully rubbed-down with a toothpick....
....and folding-back, I must say that I was amazed with how well it went down...!
The positioning was then adjusted for the next two lines, although for some reason I rubbed-down all three of the supplied running numbers, rather than just '13'.....
The process was then repeated with the white lettering itself...! More care was needed for this step, as you of course need to align the white with the shading, which although not difficult, does take some care....
Must admit that I was slightly concerned that the lettering wouldn't show-up against the light grey body colour, but am pleased that it does reasonably well!
Lettering has been completed with some Fox builders/registration plates and (if you look reaaally closely) some 'OIL' lettering (an old Slaters sheet) above some of the axleboxes (although not all of them, as the brake lever and wagon label clip are in the way.....)
Once everything has dried it'll be followed with a coat of sealing varnish then finished-off with the wheels and buffers.
Cameron.
Cameron.
