L&MR Rocket
When I recently picked-up a Revell kit for a UP 'Big Boy', I decided that I should probably start-off at the other end of the scale to enable the two ends of the 'scale' of steam locomotives to be captured...!
Whilst of course the Hornby LMR Rocket model is very nice, as I don't actually need one, and it will be a 'shelf queen', I decided to instead start with the venerable Dapol(/Kitmaster!) kit.
As the instructions make very clear, the mouldings on this are definitely not young (>50years old now!), and some of the fitment/finish as-supplied definitely required a fair amount of 'massaging' to get them to fit nicely.
Whilst this is plainly not a motorised model, one of the biggest things I think you can do is to increase the weight of the (very light) plastic model to make it more stable when placed onto the rails. - This was done by simply filling the boiler and water tank with some lead shot during the glue-up stage.
After about an hour of assembly and clean-up in front of the TV on NYE, I was left with the main 'bones' assembled. - The wheels and chimney are both completely removable at this stage to assist with assembly and painting. - A bit of a size comparison to a GWR hall that would've been ~100yrs its junior!
The look of the chimney could also be massively improved after assembly by drilling it out (slowly opened-out to approx. 3mm).
The cylinders were also assembled, but left unattached for painting...
The supplied plastic stays at the front of the boiler were substituted with some 0.45mm NS wire, which looks better (IMHO) should be much stronger (chimney removed to make this easier).
One of the other improvements was to replace the moulded pipe which goes up the LHS of the chimney with some more wire, thus after some careful carving....
(note that the glue was wet in the above photo - it dried much less 'globby' than it appears!)
Unfortunately I didn't take any photos before painting, but another big improvement was to mount each of the wheels into a drill, and 'clean up' using some emery to get the flange to actually be round! The two loco wheels are also still 'splittable' to enable them to be removed for painting.
The two figures also required careful cleanup and filling, as there were big flash and moulding sink marks on them. Whilst definitely not perfect, I'd like to think they are improved from the supplied...!
....after that we catch-up with how things are now, with everything disassembled to assist with painting.
And now following an application of white primer
To Do!
Cameron
To Do!
- Painting! - obviously
- Currently deciding how much to do with the airbrush, and how much by hand. Current intention is that the yellow and white areas are both airbrush, with the remainder by hand, but TBC.
- Final detailing
- As the cylinders are not attached to assist in painting, the two stays which attach to the chimney don't have anywhere to mount to at the other end.
- I'll be trying to keep the model 'rollable', but again TBC.
Cameron
