laminate flooring underlay
4030 Views 22 Replies 5 Participants Last post by  Smokeyone
I have some laminate underlay left over from my latest
non railway project which I am wondering if it could be used
as track underlay
http://www.screwfix.com/app/sfd/cat/pro.js...72&ts=69680
Also I have thought about doubling it up to make it 6mm thick
and trying to bevel the edges at something like 50 or 55 degrees.
The usual 45 degrees always looks wrong to me.
Has anyone any opions on this idea and is there an easy way
to bevel the edges except with a freehand knife.
1 - 20 of 23 Posts
You asked:
"I have some laminate underlay left over from my latest
as track underlay
to bevel the edges except with a freehand knife."
*** No reason not to use it. The angle should be 60 degrees. Personally I think that doubling will make it too thick unless you use thin sleepered track like C&L - Peco track/sleepers are already 3mm high, so 3mm + peco is as thick as it should be for a good visual result.
Freehand is iit unless you make a cutting jig to hold the blade - best is to use a truly sharp snap off type blade and go carefully... there's no real easy other way to do it without specialist tools.
QUOTE (Richard Johnson @ 5 Sep 2007, 13:49) <{POST_SNAPBACK}>By chance you haven't a clever way of making a 60 degree cutting jig !
The best I can think of is trying to cut a piece of wood at that angle and
then clamp the two bits of wood together again with the blade in between.
You asked:
as track underlay
QUOTE By chance you haven't a clever way of making a 60 degree cutting jig !
You need something like a "mount cutter" used by picture framers to cut bevelled edges in the mounting card. I don't, however, know if they can be adjusted for different angles.
Andrew
QUOTE (SPROGman @ 5 Sep 2007, 15:39) <{POST_SNAPBACK}>Brilliant idea, I will try and find one. Start with Google !
Andrew
No need for complexity... I think that I'd simply cut a 30/60/90 triangle from wood and use duct tape to stick a cheap snap off blade knife to it, with a bit more tape on the side that rubs against the foam so it slips well....
Creating it...
this should be almost understandable if my geometry is still OK.
To make one, the two sides each side of the 90 degrees should be 4 units and 3 units, and the third side or hypotenuse (long side) 5 units to give the angle U need.
The knife would be taped to the long side with the blade cutting where the long/mid length sides meet....
No, I'm sorry Richard those are the wrong measurements to get a 30, 60, 90 triangle.
You need short sides of 1 and 1.732 units and a long side of 2 units.
Cheers, Robert (retired mathematics teacher.)
Arghhh - I suspected I'd got it wrong - I'll go and quietly sit in the corner
[/quote]
QUOTE (Robert Stokes @ 6 Sep 2007, 03:21) <{POST_SNAPBACK}>No, I'm sorry Richard those are the wrong measurements to get a 30, 60, 90 triangle.
Doop. Mea Culpa
Geometry/Pythagorean triples Homework properly done this time - can I go home now :) :)
for 30/60/90 tirangle, 2 units = hypotenuse, 1 + square root of 3 = 2 sides at right angle
my wrongly suggested 3,4,5 gives 90, 53, 37 degrees - close but no prize :)
QUOTE (Richard Johnson @ 6 Sep 2007, 03:54) <{POST_SNAPBACK}>I'll work on the wood & tape idea.
Proper mount cutters only come in 45 degree angles unless
you are lucky enough to find an old, no longer used French
mount cutter which is 60 degrees.
I found this out after phone calls & web search.
Doop. Mea Culpa
Just thought I would report back on the underlay idea.
Played around with 60 degree cuts in blocks of wood
and blade. Tried cutting the underlay at an angle and
guess what - it tears - it's okay with straight cuts but not
angled cuts.
Of course cork might be different with an angled cut
but not foam underlay. Even with a straight cut you need
to be careful not to tear it.
** Then its the foam type (its specified as "cross-linked foam" in the ad I saw for the stuff you have), or your technique - I know as I have about 10,000metres of high quality closed-cell foam track radbed with edges cut to 60 degrees in my warehouse :). Not a tear, ragged edge or other problem anywhere!
Also... Even if its a different foam, if it'll cut cleanly straight, it'll cut cleanly angled - its in the technique and blade angle you should adopt for it...
QUOTE (Richard Johnson @ 7 Sep 2007, 04:34) <{POST_SNAPBACK}>Could it be the foam type but you would have to explain the difference to me.
I used a new blade of the snap off type and went very slowly.
Basically you'll need to angle the blades angle of cut to the foam - in otherwords, it should enter it at perhaps more than 45 degrees from the vertical in relation to the cut, as well as being at an angle for the 60 degree shoulder
(You are cutting a bevel at 60 degrees, and the blade itself should additionally be at a shallow-ish angle in relation to the direction of cut - does that make sense?)
The "closed cell foam" I use for manufacture of roadbed cuts easily and very cleanly at any angle, however I don't have an example of your cross-linked foam here to try.
I suspect that a series of light passes may give you a cleaner cut if it has any form of structural reinforcing or strong "graining" in the foam.
Experiment a bit... It will cut cleanly if you can find the technique.
QUOTE (Richard Johnson @ 7 Sep 2007, 07:32) <{POST_SNAPBACK}>I get the idea. Will give it another go and report back.
It could be me but no luck so far cutting cleanly at a bevel.
Tried several light cuts, different blades etc. The foam seems to
stretch as you try and cut it which could be the problem.
If it's the expanded polystyrene type of foam, the best way of cutting it is a hot wire cutter. As it cuts (or rather melts) its way through it seals all the loose crumbly edges.
Petal
QUOTE (Petal @ 9 Sep 2007, 17:17) <{POST_SNAPBACK}>If it's the expanded polystyrene type of foam, the best way of cutting it is a hot wire cutter. As it cuts (or rather melts) its way through it seals all the loose crumbly edges.
Petal
Thanks for the tip. Do you know by chance if the track underlay from Australia mentioned in various posts is this
http://www.barcourt.com/trackrite.htm
You asked:
**nope, its not: I am boththe Mfr and the distributor of it, and also supply to Bromsgrove models if you want a local supplier. This is the same as you can see used in my layout photos in the gallery
DCCconcepts
1 - 20 of 23 Posts
