Hi Cameron, thank you for your reply. I hadn't thought to search for lighting kits so thanks for that. I'm switching to DCC in the near future so I am swithching between DCC and DC. I'm mainly using my DC setup to make sure my locos are running properly before putting DCC chips in them.I can't speak for specific resistor values, although would probably start at ~1k Ohms when working off a 12V DC system.
I am aware that Express Models make lighting kits for Lima Class 33s, which are available in both Analogue (DC) and Digital (DCC) formats (note that there are variants for different prototypes).
Are you running DC or DCC?
Best Regards,
Cameron.
Hi Peter, thanks for your reply. I have an NCE Powercab as a DCC controller and have a DCC Concepts blue nano 8 pin with a small stay alive which I will use for my first Class 33. However after doing a bit of research the Lima bodyshell that I am using is a early Class 33 which didn't ( as far as I am aware ) have a headlight but was fitted with lamp irons. The headcode was illuminated but that was about it. I think what I'll do is fit my first one with just a chip and harness and save lighting for a later version bodyshell which had a single front and rear light.As Cameron says, 1K resistor's would be a good starting point. Wiring them for DCC will be different to DC. With the Lima loco's you'll need to not only make sure they run OK (which you're doing anyway) but you'll find that a Zimo MX600 decoder would be about the best for getting smooth operation out of those old motors. Unfortunately they seem to be in short supply at the moment. Do you know which DCC set up you'll be getting?
Hi Suzi, so far as I can see early 33's only had lights for the headcode panels so I don't really need to add them. I'm not fussed about cab lights so I'll satisfy myself with a CD motor and DCC upgrade.Get the Express Models DCC lighting kit and a Zimo MX600 decoder. This decoder will have the four outputs required to operate the four sets of lights, and it will work on DC too if you need it to. The Express Models kits are very good.
