1 - 5 of 5 Posts
Hi RayL and Puzzler
If you have wired the LS150 up as in the instructions including the separate 45VA AC power supply to the power input
the default turnout addresses start at 0001 through to 0006
if a point motor is attached to the output of that no. it should operate in your accessories mode
Hope this helps
Zmil
I was intending to use of of my several redundant Hornby power supply (as included within train set packages). Do I understand this would be unsuitable?
I have never been particularly happy with the hit and miss of Hornby point motors. Will the change of controller, and power supply help to resolve this?
It is impractical to change the Hornby points as they are very much part of the completed track laying and ballasting.
Hi RayL
The LS150 instructions say a Maximum of 16v AC but needs to be as close to 45VA as possible
at 15v that would be 3 Amp which is about the current required to change 1 Hornby point motor
most of the controllers/transformers are only about 1 Amp
Zmil
1 - 5 of 5 Posts
