Lenz Silver into a Bachmann Fairburn tank
3224 Views 11 Replies 8 Participants Last post by  dwb
After a little while away, I'm putting a Lenz silver into my (well run in) Fairburn tank.
Decoder works fine in other loco's, but when I follow Bachmann's instructions (which forbid removing the inductors and capacitors), I cannot program it on my Compact (Err 2).
Unfortunately, I've long lost the Compact manual, though I understand this means it cannot see the decoder.
Any thoughts how to program this? I cannot get the loco to move at all.
1 - 12 of 12 Posts
The manuals can be found here:
http://www.lenz.com/manuals/index.htm
The Compact manual is
http://www.lenz.com/manuals/sets/compacte.pdf
I think you need to check your wiring. Do you have any other locos with a decoder that you can use to check that the programming track is working?
Just checked... the programming track is working fine. Just programmed the same decoder in a different loco with no issues, but in the Fairburn, which is supposedly DCC ready, it does not register. Er 2 means the compact cannot see the decoder, so I suspect it is something to do with the inductors and stuff.
Before I hack around, anyone got any definitive experience?
QUOTE (icornish @ 31 Jan 2007, 10:50) <{POST_SNAPBACK}>After a little while away, I'm putting a Lenz silver into my (well run in) Fairburn tank.
Just remove them. It can't make matters worse. The inductors are probably in series with the motor so you may need to replace thenm with a wire link.
Andrew Crosland
Oh, why did I fear that! I was told at college my soldering was really bad!
Surely, DCC Ready means it should be plug and play, and not require soldering skills and stuff. Or am I just being naive?
personally I'd remove the plug and hardwire the decoder in it's a lot less work, more reliable, and will give you a much more controllable loco.
The locomotive has to meet RFI emissions standards when it leaves the factory. On DC this means having capacitors and inductors somewhere between the pickups and the track. Now it would be nice to think that these suppression components required for DC could be mounted on the plug in circuit board. However in real life, the positioning of the suppression components is critical so maybe it's not possible.
The point is that it is the motor commutator that causes the interference through the constant make/break as it spins between the motor brushes. Once a decoder is supplying the juice to the motor, it becomes the decoder manufacturer's job to ensure suppression by a combination of on board components and drive software. This renders the original stuff redundant and depending on the values involved may modify the DCC signal received via the pickups before it gets to the decoder.
QUOTE (dwb @ 31 Jan 2007, 20:20) <{POST_SNAPBACK}>The locomotive has to meet RFI emissions standards when it leaves the factory. On DC this means having capacitors and inductors somewhere between the pickups and the track. Now it would be nice to think that these suppression components required for DC could be mounted on the plug in circuit board. However in real life, the positioning of the suppression components is critical so maybe it's not possible.
That's probably the best simple explaination I've seen on this subject.
"personally I'd remove the plug and hardwire the decoder in"
That is what I did when I put a Silver in my Fairburn and removed the two suppressors from the motor housing. Runs very well. Stops within a millimetre of the required spot when running under computer control.
QUOTE (dwb @ 31 Jan 2007, 20:20) <{POST_SNAPBACK}>>Surely, DCC Ready means it should be plug and play, and not require soldering skills and stuff. Or am I just being naive?
One correction, if you leave the suppression components in place, they are between the decoder and the motor. They may affect the drive to the motor, but not the DCC signal to the decoder.
Andrew Crosland
Remove the capacitors from the motor and the one on socket board, most DCC systems will see this as short due to the way they are arranged. The RF chokes on the socket can be left in place but it is best to remove them and solder a jumper wire in their place. My cousin installed a Gold decoder and had the same problem. After removal of the caps no problems were found programming the loco. As stated in another post all RF supression is provided by the decoder.
Ozzie21
QUOTE (icornish @ 31 Jan 2007, 21:50) <{POST_SNAPBACK}>After a little while away, I'm putting a Lenz silver into my (well run in) Fairburn tank.
I bow to your superior experience. I was not presuming that the manufacturer would always put the capacitors that close to the motor end of the supply chain from track to motor.
1 - 12 of 12 Posts
