Looking for a sound file.
887 Views 9 Replies 4 Participants Last post by  hoonsou
Hi all,
I've got an LSWR Adams 02 on the way here and wondered if anyone knows of a sound file for it. Any help appreciated.
1 - 10 of 10 Posts
One possibility would be to enquire of Kernow Models, as they had this item produced.
Thanks 34C and Jeff. I'm sure I wrote a reply a couple of days ago. I emailed Kernow and they said Youchoos, but I and a friend have each had a sound file from there and we were both disappointed to say the least. Also, I'd have to send my decoder to him as he can't do downloaded sounds.
  • Like
Reactions: 1
Interesting that you didn't like YouChoos sounds. They do have some previews on their website, and a few video clips which may help assess the individual projects. I and a friend over here are very happy with the YouChoos steam sounds, owning several between us, but I can't say I am so impressed by their diesel and electric sounds, judging purely on the previews online (I don't actually have any of those).
Speaker installations do make a huge difference to sounds, regardless of their sources and which manufacturer's decoders are used, and I find a bit of experimentation helps - it is fiddly to keep soldering and desoldering speakers, but it is worth it in the longer run.
Hi Jeff,
Both of the sounds I wrote about were diesel. Youchoos don't do a sound specific for the 02, so I had a look at Digitains (my go to shop) and decided I'd go with either an M7 sound or Beattie well tank. As I've all ready got a Beattie with sound, I'd probably go for the M7, which I think would be closer. I just wonder how much room there is in the bunker for a speaker.
  • Like
Reactions: 1
Hi Jeff,
Using YouChoos sounds, I had to choose an alternative Drummond sound for my Hornby 700 class, selecting either the M7 or the T9. I opted for the T9 and altered the synchronisation with the wheel revolutions to match - John from YouChoos was very helpful with this.
As for how much room there is in the AdamsO2, I really cannot answer that. I only fitted a plain decoder in mine, so have not really looked at whatever extra space is (or is not) available.
As an aside, I did fit YouChoos sound in one of my Bachmann E4 0-6-2T locos, and that had precious little spare room. I ended up cutting away the decoder socket mounting and hard-wiring the decoder in, then sat a sugar cube speaker with a curved top on top of the decoder. That combination just squeezed into the boiler barrel behind the smokebox. Again, I can't say how much that may help you with the O2, but it does show that if you can think laterally, you should be able to find a viable solution.
Yes I can think laterally all right, but it's always good to go in with a bit of knowledge up front. I've hard wired decoders in to split chassis' so this shouldn't be a problem.
  • Like
Reactions: 1
YES he can i have many he emailed me to load myself
Last time I spoke to him which would have been a year or two back, he said he couldn't do the downloads. Thanks for letting me know things have changed.
1 - 10 of 10 Posts
