QUOTE (double00 @ 19 May 2008, 18:33)
<{POST_SNAPBACK}>What suggestions please, to make up an adaptor to feed 12v power to diesel locomotives, for easier wheel cleaning! Or is there a commercial product to enable wheel cleaning?
A question I wished I had asked. Both steam and diesel locos could do with terminals which could be concealed under a hatch/opening for the power leads to be fed/affixed. The diesel is the simplest, using the fuel tank, or central area where there is no fuel tank. The steam loco could have the same under the tender, which is even more easily done as dcc components are now been put in the tender.
All these would require a bit further design work and extra wiring (things to go wrong) but would be worth it in the end.
Hugh
