QUOTE (Expat @ 30 Aug 2008, 02:00) <{POST_SNAPBACK}>Hi guys,
Any comment on that Richard ??.
Expat.
***Yes, two different answers. One simple and the really practical one, the other the reason why one looks brighter than the other.
(1) When in a panel, you will be looking at the end of the LED only. LED's are lensed and throw most light out the front... it will look different then, and it will be quite bright enough to do its job as an indicator light.
(2) When I make a product I have to assume several things
a/ that most modellers hate soldering so it needs to be minimised and ....inevitably many will connect things up and then read the instructions. So I have to keep it simple and build a resistor into the product!
b/ The resistor has to work with any customer LED type or colour choice, as sometimes customers want to use separated LEDs rather than the bicolours, and they can be any colour they choose.
Not all LED have the same voltage or current requirements - Various colours and "standard led types" depending on brand and type can vary from 2 milliamp to 20 milliamps and much much more.
c/ Ideally each should have its own resistor but I have to choose ONE value that will allow them all to be used safely, and so to some degree, the overall level of output will vary colour by colour and brand by brand.
Red is always the brightest LED colour anyway as its so easily transmitted as a colour. Green is a little less eficient and so is less intense.
Ideally a separated value per LED would be the way to go, but then it would mean that a fixed colour always has to go to a fixed place - you couldn't easily swap red for green or yellow or white or blue..... and that would really annoy users as they want either setting to be either colour depending on the points on the layout, not the needs of the LED colour!
Expat.
