Materials for Signal Construction
2002 Views 6 Replies 5 Participants Last post by  ingenium
Recently noticed the advertisement in the recent model rail mags for Albion Alloys and not that they do a range of tube stock that is smaller than the traditional K&S Stand 1/16" brass tube. AA offer metric sizes of tube at 1mm and up and also a range of micro tube sizes at supposedly 0.5mm outside diameter.
I was thinking these smaller sizes could be of value particularly in bracket signals with rockers etc and wondered if anyone knew where I could get their items from, given I am in Australia. If I need to order in its not a problem though.
1 - 7 of 7 Posts
Finney and Smith sell a wide range of small diameter brass tubing, down to 0.3mm outside diameter, 0.1mm ID. I have only bought from them at shows, but they seem very helpful and will deal with overseas orders.
http://finneyandsmith.co.uk/finneyandsmith/Brass.htm
Thanks for the post regarding F&S and their products. A couple of interesting observations having just quickly cast my eyes across their range.
They say their micro tube is easy to drill out however I only seem to have drills as small as 0.3mm which would be limiting I guess.
Also the smallest I know of wire is 0.2mm which would mean that limiting sizes would be around the 0.7mm size tube (which is still good).
They seem to say on their regular range of tube that the Outside Diameter (OD) of say 1.00mm Inside diameter (ID) of 0.9mm yet Wall Thickness (WT) of 0.1mm. I would imagine this is just a mistake perhaps? Obviously the (WTx2)+ID should = OD. If this is the case ae we seeing 0.05mm WT tube?
QUOTE (Lancashire Fusilier @ 5 Nov 2008, 13:57) <{POST_SNAPBACK}>Thanks for the post regarding F&S and their products. A couple of interesting observations having just quickly cast my eyes across their range.
For short lengths of smaller than .3mm ID, use the tip of one of your reamers.
Or...
For a small "once only" drill below 0.3mm, use a bit of guitar string eg at o.1mm ... guitar string usually = piano wire/hardened steel wire. cut with dremel, flatten at end a little bit (hammer time :) ....and clean up sides of the flattening to leave a chisel end. Use it to clear the .1mm tubing. You might need to solder it into a bit of slightly larger tube as it will challenge a standard chuck to hold it.
No need to take a micrometer to the music shop... The diameter of guitar strings is printed on the pack - however you might need to convert the measurements to metric, as most are printed for the US market which still lives in the imperial age.
Thanks Richard. So it could have a use then the smaller tube with fine wire applications etc. I am specifically thinking of rocking mechanisms for bracket signals actually with a fine wire rocker inside a tube mechanism. Would be nice to use finer than 0.8mm wire for such a small a lightly loaded mechanicsm I think. Even if I can use 0.2 wire this would enable the bearing tube to be around 0.7mm or far less than 1/64". Much less than the 1/16" offerings at the moment.
I use Brass for my signals, I find it easy to work with.
In reply to the original question Albion Alloys have 0.5 mm 0.8 mm 0.9 mm and 1.0 mm in brass tube but also now produce 0.2 0.33 and 0.45 mm nickel silver wire. All is very high quality. I think this link should take you through to a page that contains the full range on a couple of pdf's:-
http://www.albionalloys.co.uk/index.php?/English.html
1 - 7 of 7 Posts
