QUOTE I'm new to this forum, and would like some advice:
First of all, welcome to the Forum and there's certainly some great advice to be had here. Here's my two pen'orth.
QUOTE 1) Can anyone point me in the direction of a nice layout plan for this size of board?
For a the 12' x 8' area you have indicated, there used to be (in the '70s) a Peco booklet called "Plans for larger layouts". I would also suggest buying a copy of the current issue (August) Hornby magazine. Each month Anthony New takes a theme and develops four or five plans based on that. There are usually a couple for an area about the size you suggest.
QUOTE 6) I am hoping to re-use the Peco Streamline track from my old layout (or at least the best bits of it) for the new layout. Is this track any good? I believe it is stainless.
So long as it is flat, it should be fine. For reference if you are buying more, it is almost certainly Code 100 (That's the height of the rail. Since the last time you were modelling, Peco have introduced a lower profile Code 75 rail), and it's Nickel Silver rather than stainless steel. It will almost certainly have oxidised in storage, so you will probably have to resort to some cleaning activity to get good contact between wheel and track.
QUOTE 8) My old layout was on 'Sundealer board'. Is this still a good material to use? I always thought that track pins pulled out rather easily. Also, is it a good idea to use the foam underlay for the track?
Sundeala board is still available. As you probably recall, it does need plenty of framing to provide a solid support. I use it in my loft but I find that the temperature and humidity variation make it expand and contract which is not good for the scenery and on occasions the track either. Unless you either seal it or have it in more constant conditions than I have, I'd give it a miss. As to alternatives, there are plenty and I am sure some of them will be appended to this thread shortly. If you're in a hurry, try the Forum "Search" facility at the top right of the page.
I am sure that others will be along shortly to answer your other questions. At least two of the answers will mention DCC. If you're curious to know more about that already, check out this DCC FAQ section in the DCC Forum.
