Just released by Walthers is a new HO/OO modular building system permitting the design and construction of almost any brick industrial building that you need on your layout.
If you can see it in your mind, you can build it on your HO Scale layout with Cornerstone Modulars. Choose and combine walls, roofs, windows, doors and more to create the industries you want quickly and easily!
This exciting new collection of HO structure parts make it easy for YOU to design and build almost any brick industrial structure your layout needs.
They're American prototype, fit popular modeling eras, and are designed for easy assembly. It has to be said that there will be plenty of potential for creating British and Continental commercial premises.
Each set comes with parts for a specific area of a building. Unlike traditional structure kits or assembled models, YOU choose the location of doors, loading docks, windows, roof style and more.
Whether you're just getting started or have been modeling for years, you'll achieve outstanding results with Cornerstone Modulars because each piece is engineered for perfect fit and alignment to make assembly easy. Each set also includes basic assembly instructions with loads of illustrations and modeling tips.
Just mix and match walls, doors, windows and details from the various sets - no complicated kitbashing or cutting is needed to create a one-of-a-kind industry for your layout.
Each Cornerstone Modulars set provides you with parts and accessories for a specific area of a building such as walls or roofs.
Parts are molded in realistic colors so you can use them right out of the package, but since they're separate parts, they can easily be painted if desired.
Getting started in Modulars is easy! Download the Instruction Sheet or Planning Template to help you plan and design your next HO Scale structure. The Instruction Sheet and Planning Template are in PDF format and available on the Walthers website at:-
http://www.walthers.com/exec/page/modulars
Osborn's Models of Abington in the UK stock the Cornerstone Modular packs so telephone 01235 522700 for more information.
Don't forget to say that you saw the information a Model Rail Forum!
Happy modelling
Gary
