Multimaus
7582 Views 6 Replies 4 Participants Last post by  zmil
In recent months my Multimaus set-up has become less reliable but I suspect that my use of a Maerklin 5A power supply may be the issue.
The system often shows an Err 13 error but will reset if I use Roco's own power supply.
This prompts two questions:
1. Why is this happening and how can I stop it?
2. Is there a suitable DCC set-up to replace the Multimaus?
I still wish to retain the Roco accessory modules but I do not want to use Lenz as I dislike the LH100 and LH90 because I find them non-intuitive when used on a small intensive shunting layout.
Is there a simple, DCC set-up that uses a handheld with full range rotary speed control (not centre-off) and easy to use turnout control that will work with my existing system?
Thank you
1 - 7 of 7 Posts
Hi 72C
I use a MultiMAUS myself
ERR 13 is "no master controller found"
You may have a dodgy cable or connection The Master control uses all 6 connections in the RJ12 plug
The slave uses only 4
I use the MultiMAUS through its own system with a Laptop powersupply without any problems ( about 14.5 v measured at the rails)
I also use the MultiMAUS with a Lenz LZV100 (the command station type you get with set90 or set100)
Then you get the ability to read CVs
I agree with you about the LH90 and LH100 the MultiMAUS is much easier to use
Invest in a New Roco Curly cable (like telephone cable) , the flat straight cables are prone to wire breakage after a time ( I personally have had only one fail)
I'm waiting for the MultiMAUS Pro to be released although I will not be in any rush to buy
Hope this Helps
Regards Zmil
Hi Tim,
have you had a look at the DCC systems chart above. Digitrax may be your best bet for the rotary knob however I'm not sure about compatability with the Roco accessory modules.
Neil
QUOTE (72C @ 12 Nov 2008, 07:56) <{POST_SNAPBACK}>In recent months my Multimaus set-up has become less reliable but I suspect that my use of a Maerklin 5A power supply may be the issue.
Thank you
*** I'd look at the NCE PowerCab - it has full rotary plus PB speed control, and is very instinctive and easy to use, yet has very full functionality compared to most larger systems - all for appx GBP100. It will control the Roco accessory modules and has a clean upgrade path with no wastage if you want a full high power system later. Turnout control is easy = press accessory button, choose accessory number, press enter....
everything is in the box when U buy it.
Hi Tim
Did you try a different cable ?
Regards Zmil
Zmil,
All is well. I replaced the Maerklin 5A transformer with Roco's own that came with my spare Multimaus set (the original had died which was why I used the Maerklin unit)
No further power outs and the loco decoders don't get too unhappy. I also added a power limiter from Arnold's, the guy who sells Zimo, it has a dial-up power regulator and a huge heat-sink.
The system seems a lot happier (and so do I)
Tim
Glad you got it sorted Tim
Regards Zmil
1 - 7 of 7 Posts
