Listed on another thread, but worthy of its own I think.....
My mate has a problem with his Power cab, which seems not to be unique to him - other forums have similar messages.
Basically, it concerns function control. If he puts light on on a loco, and/or sound - without even setting the loco to move, then selects another loco, and then goes back to the first one (by entering the address), the first loco "resets" - i.e. lights and sound off. It even does it it you select a loco, switch on lights and then input the loco number again - it swtiches all selected functions off.
He is aware that he can swap between two locos using the recall button - and as wiggy points out in his review on this site "The recall stack just means that when you run two locos, by pressing the RECALL button will swap between the two running locos, the speed and direction are remembered and stored so if you speed it up it will speed up from its current speed, to add a 3rd loco you will need to press SELECT LOCO then the loco address then enter.
When you do this one of the other locos will be forgotten by the cab, it may still be running but the speed and direction will not be saved you will need to re enter its address to control it again, but as its not in recall memory as soon as you change something it will default to a stop and start from a stopped position.".
But that should only apply to speed and direction, not the functions. His previous systems (even the Hornby Select) let you do this without affecting functions. If this was "correct", then pie man largers "mass startups" couldn't be done, because going back to a previously selected idling loco would shut it down.
he's spoken to the supplier of his system who is trying to replicate the situation on his own system......
So, is this a "feature" or a problem of the power cab ?
I would assume that the decoders should remember "running" functions (such as lights and sounds) and only switch them off only when an "off" command is received ?
