QUOTE (steamrailuk @ 20 Jul 2008, 16:54)
<{POST_SNAPBACK}>hi there dinwiddy after reading your comment i finally came across a pics of bachmann thomas.
http://www.trainbuddy.com/Reference/Decodi...ines/thomas.htm
Unfortunatly it looks like you were correct about the body being integrated with the chassis
. I may still attemp to use it but may need a lot of careful planning to make it work.
I'm hopeful that the bachmann junior 0-4-0/ percy doesn't have the same chassis setup though
Hi steamrailuk.
I have looked at thomas and it doesnt seem to bad the thing to be sure of is the wires are long enough to go through the components and not cut too short .... the authors comment "Nothing bigger than a 15 watt iron and around 6 and no more than 10 seconds applying heat." i wouldnt reccomend such a long time with an iron especially on motor brush hoods as it melts the housings .. i tin the wire then apply flux to both the wire and motor contact touching it with the iron for 2 sec if that as soon as it hisses usually the solder has melted suffieciently to join the parts .
I am not sure of the dimensions fo the digitrax DH121 but a good decoder to go for is the TCS M1 (£16.50) small two function easy to use and economical and ideal for OO the TCS site shows a T1 decoder (£11.50) fitted using a 9 pin socket which makes it even easier to convert , and several other thomas related engines on this link ... in the bachmann section.
http://www.tcsdcc.com/Installation_list_by_Manufacter.htm
