QUOTE (COACHMANN @ 19 Feb 2008, 20:03) <{POST_SNAPBACK}>I wondered if there is any reason why they would not fit Peco Code 75 points? Does anyone know the price of this surface unit?
Coachmann
They can be bought for around £4.50 - 5.00. I will try one out on a code 75 point this week and post the result.
They are pretty useful because they can be fitted under platforms and allow low level superstructures on the side of layouts. At present most of my point work is actioned by PL10's (surface mounted - I couldn't gather enough time or energy to fit the point motors under the board) located on the board edge with rodding connected to the points. The height of these PL10's prohibited fitting in inclines in the area these were situated. I can now use the PL11 either adjacent to the points themselves, as they fit between the parallel tracks, or simply replace the PL10's. In respect of the post about using a CDU, which is what the makers advise, my accessory decoders are using either 5A off the main controller, or 3A off the Lenz TR100's, which seems ample for the job in hand. One of the point motors has been attached to the SMD82 accessory decoder, which has a CDU onboard, but run off a separate bus allocated to point accessory decoders.
The view can be taken that they are too large to be realistic, but they do the job, and can be more easily hidden/disguised. How long they will last is another matter. The nearest I have seen to these are Shinohara system point motors, which look very similar, although I have yet to handle an example.
Hornby have yet to produce their version.
Sorry, Coachmann, if I have hi-jacked your post to reply to other posts.
I have bought from MG Sharp at Sheffield and Kent Panel Control who were at the BRM Railway Ex. at Harrogate.
Hugh Williams
Coachmann
Hugh Williams
