QUOTE (mikeg @ 5 Oct 2007, 12:02)
<{POST_SNAPBACK}>I am glad I asked the question then.........it's a viessmann 5246 and I am trying to wire up an old
athearn. I have tested it and it works okay but the decoder gets more than just warm. The motor and
drive is the same as this.......
http://www.tcsdcc.com/decoderpics/Athearn%...thearn_sd45.htm
also it now runs very noisely which it did not on dc but I understand other people have had this problem.
You have not said which type of decoder it is but I would not remove the plastic sleeve as this is for insulation and make the location to place the chip easier. If you remove it you may find that if it moves it may short out on part of the loco chasis and thats one dead decoder. Some of the chips that come with a sticky pad to attach one side still need the surrounding metal parts insulating to stop the chip touching any metal parts whilst assembling the model. I have found that most chips do not get very hot unless you overload them, normal running barly gets them warm.
hope this answers your question
mike g
